Avanti Radio Suppressor Question
  • Electrical: Avanti Radio Suppressor Question
    Does the radio suppressor that is for the voltage regulator connect up to the battery terminal on the regulator? If not, which terminal does it connect to?
    A 0.5uF Cap can be installed at the BAT or ARM terminal. But not the Field Terminal. Depending on noise magnitude, a cap could be installed at the Generator / Alternator armature or output terminals and one at the BAT terminal of the regulator. No damage done at any location. Everything to gain for noise suppression. Cap case must be firmly ground to device to be effective. TT
      Don't forget the positive side of the ignition coil too. NAPA has the correct caps, the part number is RC1. Bud
