How are they measured?
  • Drive Shaft: How are they measured?
    Are the driveshafts measured center to center of the universals? I need to get the one I have shortened by 19/32"! That's why I had so much trouble getting it out and then back in.
    Chip
    '63 Cruiser
    '57 Packard wagon
    '61 Lark Regal 4 dr wagon
    '50 Commander 4 dr sedan
    For a one piece drive shaft, at normal driving height, you measure from point to point, where the universal caps will sit in the yoke saddles.
    64 GT Hawk (K7)
    1970 Avanti (R3)
      Okay, where in the saddles? Outside, inside, center?
      Chip
      '63 Cruiser
      '57 Packard wagon
        Chip
        If you know the amount you need it shortened 19/32", isn't the technique irrelevant. If it is just to measure after the mods to assure correctness, just find a fixed point on each end and measure before and after.
        Just thinkin', Bob
          If you are using the parts books, the measurements given there are C-C on the U-joint bearing cups. I had one made to spec w/ those measurements for my '55 coupe (using the length for a GT Hawk w/ 4-speed and Dana 44) and it fits.
            Chip
            Just thinkin', Bob
            You are right Bob, it doesn't really matter, I just wanted to compare what the book says it should be with what I measured.
            Chip
            '63 Cruiser
            '57 Packard wagon
              If the "Book Number" is 535460, 535461, 535462, 1541746, 1541747, 1541748, 1541749 or 1541750 I can just email you a photo copy of the BLUEPRINTS and you can go from there.
                I suspect being in South Bend, that you mean you will send Chip the BLUEPRINTS, not the driveshafts represented by those numbers!
                  Hopefully …just clarified my previous post. Thank you!!!
                  As a clarification to your above comment; anyone, any place in the world (even in Ferndale, WA, USA) can order a reproduction of a Studebaker engineering drawing. Here is the link you can follow to order them: http://www.studebakermuseum.org/p/ar...e-collections/
                    Ah, that makes more sense! The part number is 1547658. Thanks anyway!
                    Chip
                    '63 Cruiser
                    '57 Packard wagon
                      I got the driveshaft shortened. Now instead of having to force it in, it was a breeze! I have about 1.25" of the yoke exposed instead of .625.
                      Chip
                      '63 Cruiser
                      '57 Packard wagon
                        Thank you Welcome, I was aware of that, however I figured you are able to go there and maybe pay a bit less without shipping and their hourly rate to do the search, only your own rate whatever they charge for that, so you would be doing it more than most of us "away from it all" people!
                        Quote: "Engineering Drawings
                        A-size: $5
                        B-size: $10
                        C-size: $20-$30
                        D-size: $30-$50
                        Rolled Drawings: $15/foot
                        All prices quoted in addition to hourly research fees.
                        Shipping not included."
                        I would think there would be minimum to no research fee if I send them a Drawing/Part Number to pull and print at these rates, YES?
                          THE WORKProject du jourTHE REWARD
                          As you walk down aisle after dimly lit aisle in the archives filled with pictures, documents, drawings and you first realize you are walking through the heart of what remains of the Studebaker Corporation IS the reward!!!
                          Rich, come to South Bend a week earlier or stay a week later than the IM next summer and maybe you too can be a Volunteer.
