If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You will have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
You probably will have to raise the engine about 1 inch to allow the manifold to slide into place but that is not your major worry. When you get it on and the engine lowered it will contact the top of the pitman arm. The solution is to raise the engine with shims until it clears, bearing in mind hood clearances on an Avanti or grind off the top of the pitman arm a bit. You may also have to grind off about 3/32" from the underside of the manifold where it contacts the pitman arm. This is the only way mine fit.
