Rocker arms clattering again
  • Rocker arms clattering again
    Is it 'normal' for the valves to go out of adjustment in only a few hundred miles?
    I adjusted them not that long ago, and now 2 or 3 were really starting to clatter rather loudly after driving for awhile and getting the motor up to temp......they are nice and quiet at start up, though.
    So I pulled the valve cover on the passenger side (motor still nice and hot) and found #2 & #8 to have nearly .032 valve lash. I brought them back to .025 and buttoned it up...now, it's reasonably quiet again.
    Am I doing something wrong here or possibly missing a step? The half-inch adjusting nut(s) are self-locking aren't they?....that is, there isn't some way of actually "locking" them in position?
    1962 GT Hawk 4sp
    The nuts sometimes will lose their interference fit and work loose. They should be very hard to turn unless they are worn out.
    JDP/Maryland
    63 GT R2
    63 Avanti R1
    63 Daytona convert
    63 Lark 2 door
    62 Lark 2 door
    60 Lark HT-60Hawk
    59 3E truck
    58 Starlight
    52 & 53 Starliner
    51 Commander
    JDP Maryland
      I have a similar problem. Has anybody tried "red" loctite on these?
        If I were to use the Loctite . It would be the Blue. The Red is just what it says. A thread locker, will need heat to break loose.Like JDP said they should be hars to move. May need to replace them.
        63 Twin Supercharged Avanti
        64 Avanti R3w/NOS
        88LSC Avanti 350 Supercharged w/NOS
          64 Avanti R3w/NOS
          Oh, no no no...no Loctite...I wanna be able to take it apart when/if the time were ever to come. Besides I'm not all that crazy about introducing a foreign substance (which hardens) into the path the oil takes.
          So, to save me the time in researching this matter of replacing the worn locknuts, I presume all I have to do is undo the rocker-arm shaft assy? Any particular words of wisdom in regards to this sort of venture?
          Thanks in advance,
          Karl
          1962 GT Hawk 4sp
