Removal of exterior windshield stainless from a '62 GT Hawk
  • Body / Glass: Removal of exterior windshield stainless from a '62 GT Hawk
    I know I've seen discussion of this on earlier cars ('53, etc.), but I'm ready to remove these moldings from a '62 GT Hawk before painting the car and I cannot see how to remove the moldings.
    Thanks in advance!
    '62 GT Hawk (4 speed, A/C, Power steering - running and DRIVING!)
    I believe it is like the '64 Daytona, in which I sat centered in the front seat and placed my feet flat against the windshield and gently pushed until the entire windshield popped out. The glass didnt break and the stainless can be easily removed after pulling the rubber off of the glass.
    In the middle of MinneSTUDEa.
      Someone correct me if I'm wrong but, I believe the molding cannot be removed without removing the windshield. Likewise, cannot be installed without assembling with glass and gasket first.
      Should be the same as this procedure from the '53 Shop Manual.
      '33 Rockne 10,
      '51 Commander Starlight,
      '56 Sky Hawk
        Thanks very much to both of you.
          Helps to park car in the hot sun for a while before attempting to push windshield out.
          Frank van Doorn
          Omaha, Ne.
          1962 GT Hawk 289 4 speed
            Thanks for that info Frank.
              Park in the hot sun for sure. That lessens the chance of breakage. What I have done too in the past is start on the inside with a wooden or plastic tool glass installers use which looks somewhat like a carpenters pencil. I fold the lip of the windshield weatherstrip off the pinch weld on the inside & work it around, starting from the top & working it to the sides. This releases the grip the weatherstrip has on the body & will enable you to gently lift the glass out & off the car without assistance or breakage.
              60 Lark convertible V-8 auto
              61 Champ 1/2 ton 4 speed
              62 Champ 3/4 ton auto
              63 G.T. Hawk R-2,4 speed
              63 Avanti (2) R-1 auto
              64 Zip Van
              66 Cruiser V-8 auto
                Thanks Warren!
