Ok this one has me stumped. It's my son's car and we can't seem to figure out what is going on.
The car is a 1960 Lark with a 6 cylinder and 3 speed manual trans.
We have installed new plugs, wires, cap and rotor. Changed the coil and set the timing. The rotor turns when you turn the engine over.
The problem is it doesn't have spark. Oh and the engine turns over, just no fire to the plugs.
The po had done some weird stuff.And we have since removed what he had done thinking this was the no spark cause. He had installed a ballast resistor and ran a wire from the unused terminal on the starter solenoid to the coil.
We took that off and hooked up the white wire with the pink? strip coming from the ignition switch to the coil and used a non ballast resistor required coil, we even swapped the ign switch.
Any ideas are welcome. This is a really neat little Lark that we want to save.
Thanks,
Thanks,
