Radiator fan blade
  • studegary
    Studebaker did offer heavy duty options for fans. I put a factory option five blade with a lot more pitch on a 1953 Commander. It was noisier, but did move a lot more air and helped with slow speed cooling. I do not know about a 1952 Champion. Perhaps someone with the appropriate parts book could check for you (assuming that you do not have the parts books for your car).
  • CHAMP
    I got an aftermarket flex fan and a spacer from NAPA. The spacer had to be made larger to fit the Stude water pump shaft. I had a friend with a metal lathe so it was no problem.
  • cammeron
    started a topic Cool/Heat: Radiator fan blade
    Radiator fan blade
    52 champion regal starliner 6 cly is there a fan blade with more than 4 blades that will fit?what about power sterring unit? Thanks gary
