I have a 56 President 56H, Serial number # 7810358, 3 speed, overdrive.
Rearend tag is 47/12, the driveshaft turns a little less than 4 and 1/3 turns to 1 drum turn. [what is this ratio and is it correct ?]
10" drums, 7/8" wheel cylinders.
According to the 55-58 Chassis Catalog the outer flange gaskets and outer oil seal retainer looks like the one for a 56G [pg343], NOT like for a 56H [pg344].
Also on both wheels the hubs were grinding themselves into the backing plate. Almost halfway through. Neither wheel had shims to adjust endplay. I haven't checked endplay yet.
When I pulled the hubs both nuts were only tight to about 20 lbs and both hubs pulled off with NO effort.
The manual isn't clear on how to check endplay other then dimensions so I will need some coaching on that.
Thanks for any infirmation you can give me.
Dan
Dan
