6 volt battery cable upgrade to 2/0 gauge, car starts much better
  • Electrical: 6 volt battery cable upgrade to 2/0 gauge, car starts much better
    I upgraded my 54 champion from 2 gauge cables on the positive and negative battery terminals to 2/0 gauge cables. he car cranks faster, and starts much better, especially warm. Both cables were the 24" length versions from my local Fleet Farm store, and they were less than $10 each in the battery section. These heavy cables are meant for tractors or heavy equipment, and I used a black cable for both units.
    Best $20 I ever spent !
    54 Champion coupe
    48 Champion Convert
    Great! Easier than converting to 12 volt.
      That's what I used on my '54 Champ. It started in the coldest weather with no issues.
      Chip
      '63 Cruiser
      '57 Packard wagon
      '61 Lark Regal 4 dr wagon
      '50 Commander 4 dr sedan
        Me, too. Kept the 6 volt and went to 00 cables. They look pretty tough, too. I also bought my battery from a farm supply. The car is flooding (rebuilt carb on the way), but that battery and those cables always got it started again. And I learned it all through the SDC and this forum.
          don't know what the flat cable is rated, but it replaced a 2 gauge cable and it's faster starting!
            I use #00 for all of my 12 volt, in the trunk conversions also. Works very well. I normally use welding cable for its use of MANY fine wires rather than just a few stiff wires. Never really have had any problems with the insulation like some seem to warn about.
            None of the #2 or #3 cables they sell in "conversion kits". The smaller wire sizes just don't let the amps flow freely..!
              Connect the positive cable to a starter mounting bolt, make sure the ground strap from engine to frame is in good shape. My 55 President sounds and feels like it's got 12 volt to it. I had custom cables made up. Starts without hesitation hot or cold.
              South Lompoc Studebaker
                Found out why my car runs rich. When installing the rebuilt carb, noticed a seal missing on the heat riser tube to the automatic choke. Sucking in hot air from the manifold after it's warmed up. Gawd I wish my good old boy would have read the manual.
                  Speaking as an electrical engineer, having the heavier gauge cable is paramount for 6 volt systems. The reason that cars start better with the heavier cables isn't just because the stater turns the engine over faster. It is also because the cable has a low resistance and when starting, there is less voltage drop across the cable. This allows more voltage for the ignition system to function properly.
                  1948 M15A-20 Flatbed Truck Rescue
                  See rescue progress here on this blog:
                  http://studem15a-20.blogspot.com/
                    I agree with the increased gauge. When I installed my new Cathcart Stg-4 Eng in 2002 I rebonded all motor-trans-frame-body points with fresh NAPA braided bonding straps.
                    The 6-Volt Pos Grd Batt cable is a heavy duty braided strap and the Neg cable (with in-line disconnect) is #00. Have enjoyed strong cranking and quick starts ever since.
                    Definitely the way to go.
                    StudeBakerHarv
                    * 1950 Champion Starlight Coupe (Cathcart Stg 4 Engine)
                    * 1971 Avanti II (RQB-1659).
