I have power steering in my '54 Commander, the Saginaw unit. I did some research, seems like the box takes grease and the power steering reservoir takes ATF?
54 Power Steering
Correct!!!Originally posted by Schraders View PostI have power steering in my '54 Commander, the Saginaw unit. I did some research, seems like the box takes grease and the power steering reservoir takes ATF?
Opinions may vary, but I use STP brand power steering fluid (because a Saginaw rebuilder recommended it
) in the hydraulic side and Semi-fluid Steering Box Grease (p/n 801651) from Studebaker International on the gear side of the system. (The grease from S/I is $20 bucks for a 10 oz. tube, so make sure you know how much you'll need before ordering!!!
I am preparing to start my '54 with original power steering in the near future. I don't know how long it has been since it was in operation so would it be advisable to have it rebuilt. If so, who would I need to contact? Are these units reliable?
I have one of them in my '53. Lare's Mfg in Minnesota will rebuild them is needed.
I think SI has some of the seals and other parts too.
Interesting about the fluid... I originally put dextron III ATF in mine but found that if I drove the car on the interstate at 70mph that the pump would whine something aweful when I pulled off and stopped at the light. After driving at slower speeds for a while, it would tone down. I suspected the fluid was foaming. Somewhere I got the idea to try type FA fluid instead and it really helped a lot with that whining. Its pretty much cured now.Opinions may vary, but I use STP brand power steering fluid (because a Saginaw rebuilder recommended it) in the hydraulic side
Jeff in ND
