Brake line flaring tools, recommendations?
  • Brakes: Brake line flaring tools, recommendations?
    I'm about to replace all the brake lines on my Cruiser as part of my 'Turnerizing' of the brake system. Bought a 25' roll of steel line, just to change my mind and decide the Copper/Nickel stuff is what I want on the car.
    What to do with the steel line? Practice my flares, of course!
    Problem is I kept making off-center flares!
    I looked at my flaring tool and found the pin on the adapter is bent. It's a cheap one, bought from Auto Zone. OEM brand, I think.
    Can anyone recommend a better one that won't cost more then the Turner kits I'm installing?
    Thanks!
    I recently purchased a nice double flare tool from eastwood,com. It works great and is almost hard to make a poor flare. It is expensive. List in their lastest catalog at @249.99. They had a sale recently and I got i for $180 with free shipping.
      take it back
      Thanks!
      go to harbor freight and get a different packaged one. What is the problem with steel brake line? I got'sta kinow. jimmijim
        If you have a good old school NAPA parts store in your area, go to them and see what they are selling the garages in your area. See if they have a good old name brand such as Imperial Eastman or Milton. There are others that work just fine. Shouldn't cost an arm and a leg either. Make sure you get the double flaring unit. A NAPA sales tech worth his salt will steer you in the right direction.
          How long you want them to last?
          http://64.90.169.191/applications/au...rake_tube.html
          If I can do a job once and be done with it, even if my heirs sell the car after I'm a memory, and at a reasonable price, why not?
          Steel lines I'd have to replace again if I keep the car (and live as long as my dad did.)
            Anyone try the Craftsman (Sears) double flaring tool?
              I have a Craftsman one but I prefer the K-D one I bought years ago. Neither was that expensive. The smallest double flare adapter is a consumable unfortunately. It'll last longer if you use a sharp cutter, and dress the cut end of the tube with a flat file and deburring tool (inside) to make sure end is square and 100% symmetrical in every way before each flare.
                just a tad
                I would expect them to last as long as my car is old as it is a 63 Hawk and has never been and as long as I own it be sublect to calcium chloride covered roads.
                  Excellent point! Preperation is key. Simply cutting and crunching the ends with the tool will get inconsistant results.
                    I believe the lines on my car are mostly original, and I don't plan to let the car see salty roads, but I still prefer to improve little details when I can. That's why the Turner brakes are going on all four corners, and a dual master is feeding them. That's why the points got replaced with a Pertronics.
                    Don't get me wrong, steel does the job, and with avoiding salt, might for a couple decades. Just not sure I'll want to re-do my lines again when I'm in my 70's.
                      just a few decades
                      I would expect to expect them to last at least as long as my 63 Hawk is old even if it happens to be a rust free unrestored survivor. If the steel replacement line is of equal metalurgical quality as OEM type and under non snow belt circumstances I would say it to be fine. I may consider a set of Brazilian made rubber brake lines for a project car I intend to flip. cheers jimmijim
                        Another reason I'm not using steel lines, I opened up the rear wheel cylinders and found extensive pitting. If the inner walls of the cylinders rust, why not the lines?
                        Here in MD it gets humid, and I might forget to flush the brake system one year. DOT 3/4 fluid absorbs moisture, even the synthetic stuff I use.
                        The steel lines might outlast me on the Cruiser, but I choose not to chance it. Besides, I'll need to replace the lines on my 'new' '81 Ford F-150 Winter Beater, and I know the steel would rust there!
                          I like imperial brand tools, I've had mine for years I hope they're still made in the USA. Try this website they used to sell imperial but the description of the tools doesn't say so give them a call.
                          Read they're tips on how to flare. The key is square cuts, and preparation before flare like chamfer the outer and debur the inner...........mostly practice practice practice. I'd buy a few 3/16 double flare buttons they are easy to bend and break. If you extend the tubing too far into the fixture for the first step you will bend the flare button. I have they're 3/16 bender and its a nice one, the multi size benders are usually too big to make tight bends.
                          http://www.inlinetube.com/
                          Thanks!
                          53 2R6 289 5SpdOD (driver)
                          57 SH (project)
                          60 Lark VIII 2dr sd (driver)
                            like gmax , i also got the flaring tool from Eastwood when it was on sale and it works awesome !!!! and does SS. you can go to their
                            website and watch a video.
                            good luck
                              I stopped by at an O'Reily auto parts store today & noticed they load double flare kits out. You might try them or one of their competitors. The price would be right at least!
                              60 Lark convertible V-8 auto
                              61 Champ 1/2 ton 4 speed
                              62 Champ 3/4 ton auto
                              63 G.T. Hawk R-2,4 speed
                              63 Avanti (2) R-1 auto
                              64 Zip Van
                              66 Cruiser V-8 auto
