Rear axle bearing interchange?
  • Rear Axle: Rear axle bearing interchange?
    About to do the rear axle on my '51 Commander. Am looking for bearings and cups equivalent to Studebaker numbers 530451 and 165167.
    I checked Nate's list and there's nothing there. Anyone have a crossover number for Timken, SKF or...?
    '33 Rockne 10,
    '51 Commander Starlight,
    '56 Sky Hawk
    I have not had to do this in a long time but, forget the Studebaker numbers. Take the bearing and bearing race (cup) to your local industrial bearing distributor (one with a sales counter for walk-in's). They should be able to match it with an available equivalent. Many of these bearings are standard for industrial (not just automotive) applications and still available.
    Take good care of the race. They are more likely to be difficult to get.
    The problem with old bearing races is that many of them were made specifically for the car manufacturers and although the proper taper to match the tapered roller bearing is available...a bearing race with the proper "outside" diameter may no longer be made.
      The tapered axle bearing are all the same up to 64, 14132T for cone and 14276 for the cup
        Pull one out and check for numbers. Timken marks theirs...
        1948 M15A-20 Flatbed Truck Rescue
        See rescue progress here on this blog:
        http://studem15a-20.blogspot.com/
          You can get them at Rockauto.
          BR14276 & 14132T
