2R-15 brake cylinder interchanges?
  • Brakes: 2R-15 brake cylinder interchanges?
    Hi All, My plans are to tear down the brakes on the 49 2R-15 after I finish some other projects this evening or tommorrow afternoon. I blew a wheel cylinder with the resulting total brake failure the last time I drove it. Luckily I hadnt ventured into traffic with it so the brake failure was scary but no real issue. Does anyone know of a direct FLAPS replacement for the wheel cylinders or am I relegated to use the SI replacements? Can anyone confirm that the ones supplied by SI are in fact direct replacements? Thanks, Steve
    As I understand it, rear wheel cylinders are unobtainium. Does SI have front cylinders for a 2R-15? I too would like to know if there are replacement fronts at NAPA, etc. One of my fronts has a slight leak.
    Rick
    Kingman, AZ
      If your truck is a 2R-15 as you state my suppliers catalog lists Studebaker part# 683448 & 683449 1 3/8" (2 per side) dual rear wheel cylinders at Around $67.00 a pc. X 4=$268.00 Fronts I do not see listed for a 2R-15. Most of the vendors buy from the same supplier so you can buy from any of them. They may have to order them for you.
      Frank van Doorn
      Omaha, Ne.
      1962 GT Hawk 289 4 speed
        That's interesting. The parts manual shows the rear brake with two cylinders per wheel (FR2 type) AND the hi-tork rear brake, which is what my 1949 2R-15 has. However, the service manual only shows the hi-tork. Anyway, the hi-tork cylinders are the ones they tell me are not available anywhere.
        Rick
        Kingman, AZ
          Thanks Guys. I ran out of time and didnt get mine torn apart yet. How do I tell if my truck has hi-tork cylinders or not? Thanks, Steve
            Rear High Torque cylinders are available. They're priced in the neighborhood of $175.00 ea. Fronts are available, also. I don't have price information on them at the moment. Bo
            Bo
              This is a Hi-Tork rear wheel cylinder.
              Bo, where can we buy the front and Hi-Tork rear cylinders?
              Rick
              Kingman, AZ
                I have one of the hi torque wheel cylinders NOS in the box available. Only problem is I don't have the proper parts manual to know what it fits,front or rear. part # is 666110
                Frank van Doorn
                Omaha, Ne.
                  Frank-
                  666110 is left rear.
                  Skip Lackie
                    It fits a 2R-14, 15, 16 & 17.
                    Rick
                    Kingman, AZ
                      Thanks Skip!
                      Originally posted by Skip Lackie View Post
                      Frank-
                      Frank van Doorn
                      Omaha, Ne.
