rear swaybar and reaction arm /rod
  • rear swaybar and reaction arm /rod
    Hello to you all,the next subject on my hawk gt is the installation of the above items I have seen the pictures in the forum last time
    I have some options: from junk or original if I can find them.
    Questions are about the measurements in/on the frame and the dimensions of the materials,thanks very much for your info
    I believe that Studebaker International carries the whole "kit".
    Tom
      Or if you can find a mid-50s sedan parts car it will bolt right up (it's all the same stuff) make sure you get the spring plates too.
        Since this gentleman is located in Holland (my country of birth)it probably would be hard to find a parts car,best option is to purchase from S.I. or a vendor that has this used.
        Frank van Doorn
        Frank van Doorn
        Omaha, Ne.
        1962 GT Hawk 289 4 speed
