Have a '63 289 and the heads are now being completed by the engine machinist (after my moderate "cleaning-up"). Have been looking for valve spring shims that would fit into the bottom of the spring snubber - No luck. The machinist suggested placing the shim(s), if needed, under the snubber, which would allow the use of standard size shims.
My question is, will the "under-the-snubber" location allow the snubber to "walk" out of position ? There is only a 1/8 to 3/16 inch step to keep the snubber in place - The machinist does not think that a shim of 1/16 inch or less would cause a ploblem and that the step is not really needed to keep the snubber-spring in place. What are your experiences and opinions?
Also, there has been some discussion of standard force springs vs. heavy duty. Has anyone recently experienced excessive cam wear w/ the heavy duty springs. assuming the proper amount of zinc in the oil (1200 to 1500 ppm)?
Any veiwpoints and/or experience would be appreciated.
Thanks in advance, Paul TK
