Is there a way to tell....
  • Rear Axle: Is there a way to tell....
    Is there a way to tell from the build sheet what axle ratio my R-1 Avanti (with auto) has?
    63 Avanti R1 2788
    1914 Stutz Bearcat
    (George Barris replica)
    Washington State
    Production Order
    John - In my experience with several Production Orders, the axle ratio is printed right on the PO under the "Axle Ratio".
    Mark Hayden
    '66 Commander
    Zone Coordinator
    Pacific Can-Am Zone
      Chances are, it was built with a 3.73. Forty-eight years later, could be anything. Why not just put it on a hoist and count the driveshaft vs. wheel revs? Takes less than five minutes.
      jack vines
        I don't see that on my copy....engine, body, key numbers, yes. But no Axle Ratio box.
        Honest....
        jack vines
        No hoist...
        63 Avanti R1 2788
        1914 Stutz Bearcat
        Washington State
          John
          Take it out on the highway with your GPS and run at a fixed speed. Record RPM and speed, when you return home measure rear tire diameter and plug them into the speed/gear ratio equations on the internet. With the final drive at 1:1 the only unsolved variable is rear ratio.
          I know!!!! No Gps
          Bob
            Originally posted by JBOYLE View Post
            No hoist...
            Do it the easy way if you really want to know. Take it down to the local garage and have them figure it out. Pay their rate and have it serviced at the same time. Problem solved...Oh no money either.
            1964 GT Hawk
            PSMCDR 2014
            PSMCDR 2013
            Victoria, Canada
              Is there no ratio tag under one of the diff. cover bolts?
                Many of those tags have been lost over the years.
                I do as Jack suggests; jack it up, rotate the tires and compare revolutions to revolutions of driveshaft.
                Brad Johnson,
                '56 Sky Hawk in process
                  No hoist, no speedo, no tach, no GPS, no money left...no foolin'
                  63 Avanti R1 2788
                  1914 Stutz Bearcat
                  Washington State
                    Gotta Jack? use it to lift one wheel. With the other three wheels blocked and the transmission in neutral, mark a chalk mark on the drive shaft and on the wheel. You count the revs of the drive shaft while someone turns the wheel one revolution. Divide by two for the ratio.
                    Don't tell me, you got TwinTraction too. in that case wait till you get money.
                      The Ratio USUALLY, only shows up on CAR Production Orders when a non-standard Ratio is special ordered. An R1 Automatic normally came with a a 3.31 Ratio, the R2's are usually 3.73.
