Avanti Horn wire
  • Electrical: Avanti Horn wire
    Hello again. I am trying to find the wire that goes through the steering box for the horn. Does anyone know where it is or how to get to it. Horn makes noise while turning the wheel. Thank you again
    Jerry
    jerry defilippi
    If I redall correctly, the Avanti horn wire does NOT go through the steering box. It is in the harness that goes up into the column, about 1/2 way up from the firewall.
    I'm pretty sure it is a white wire too.
    Jim
    their Memorials!
      Have you removed the steering wheel? The problem is probably up top near the horn contacts. The wire through the column is a ground not hot so if anything that the wire touches grounds the horn will blow.
      ErnieR
        Thank you for you help
        jerry defilippi
          Your welcome...did you resolve your problem?
          ErnieR
            Yes, thanks for you help
            jerry defilippi
