Temperature gauge
  • Temperature gauge
    I think the temperature gauge in the Daytona, went south
    sometime, permanetly, at somepoint. Either that or it is
    the coldest running car, I have ever had! What is the best
    way to check or what would you check 1st?. I am also a little
    wary of the gasoline, but the oil and amp, seem to be fine!
    I see Sudebaker Intl sales them for $65.00 a pop or are there
    any other sources and should I replace all 4 to be safe?, if
    I find there isn't a connection issue.
    Thanks....I am not a mechanic...but would like to know how to
    "root" things out.[8D]
    glen Brose
    Tumbleweed Flats, AZ
    Glen,
    Probably the simplest thing is to use a kitchen type thermometer to check on the temperature once it is in the normal operating range. I would suspect thet your car has a termostat in the 170-180 degree range. At leat you will know what temperature range your car is running.
    Once you have immersed the thermometer in the anti-freeze, DO NOT return it to the kitchen inventory. Just buy your wife a new one.
    Gary
      Thanks Gary...that is easy enough!
      glen Brose
        Next, suspect your sending unit before you look at the gauge. Then suspect your wiring..... Always look at the least expensive things first.
          Thanks Chuck....work backwards to weed out the culprit!
          Appreciate the post!
          glen Brose
