Master Cylinder
  • Master Cylinder
    I read in the repair manual that the dual reservoir MC were put on vehicles starting in 64, yet my 64 Cruiser has a single reservior MC. Which is correct and how difficult is it to change over to a dual as I like idea of having a back up in case something ruptures?
    If your Cruiser has disk brakes, the single is correct.
    JDP/Maryland
    63 GT R2
    63 Avanti R1
    63 Daytona convert-63
    63 Lark 2 door
    62 Lark 2 door
    60 Lark HT-60Hawk
    59 3E truck
    52 & 53 Starliner
    51 Commander
    JDP Maryland
      Here's a similar thread...
      http://www.studebakerdriversclub.com...TOPIC_ID=10256
      Here's the ECI dual circuit remote booster...
      http://www.ecihotrodbrakes.com/remote_booster.html
      Bellingham, WA
        Yes, a Cruiser should have Avanti disc brakes and a single master. It
        would be easy to just use the Avanti II style master cylinder and do
        a split at the front Y-block. On my Avanti, I just plugged the port
        for the rear brakes in the "Y", and used a union to extend the rear
        brake line up to the dual master. You have a swinging pedal, so its
        a simple task to add an electric brake light switch under the dash. I
        recommend the bottom one on Bob Johnstones website :
        http://www.studebaker-info.org/tech/repstuavMC.html
        Mid 70's Chrysler. NAPA # 36307.
        Item#: UP 36307
        APR07
        Price: $75.99
        Bore Size:1 1/32"
        Tom
