ENGINE CUTOUT
  • ENGINE CUTOUT
    '55 Commander with stick and OD today after about 10 miles driving in the morning with no problems and about 7 in the evening with no problem, as I was accelerating just after OD kicked in the engine cut out on me for just a fraction of a second.....then again even more briefly about 2 miles later. I'm thinking coil or distributor related, maybe points, condenser or one of the small wires. Any ideas?
    '55 Commander
    '55 President
    \'55 Commander
    \'55 President
    Could even be a sticking OD relay since it interrupts the ignition when the OD kicks in.
    JDP/Maryland
    63 GT R2
    63 Avanti R1
    63 Daytona convert-63
    63 Lark 2 door
    62 Lark 2 door
    60 Lark HT-60Hawk
    59 3E truck
    52 & 53 Starliner
    51 Commander
    JDP Maryland
      OK, I can try to check it out and clean the terminals and points.....maybe it was agitated by the 90 degree weather which it hasn't seen in awhile. This did occur both times right at OD engagement. Thanks.
      '55 Commander
      '55 President
      \'55 Commander
      \'55 President
        Could be the overdrive kickdown switch on the throttle linkage. If it were sticking, it could cause the engine to cut out. It is supposed to just interrupt the engine for an instant so it can kick out of overdrive (like a passing gear). If it was to stick, it could kill the engine.
          Let's not forget that that switch works in concert with a pair of contacts in the solenoid as well.
          Miscreant adrift in
          the BerStuda Triangle
            OK, areas to check. Thanks.
            '55 Commander
            '55 President
            \'55 Commander
            \'55 President
