Control Arm Spreader Tool
  • Control Arm Spreader Tool
    Is there an alternative way to spread the outer control arm .015, I did not see a torque spec on how tight the bushing should be.
    I was thinking of cutting a solid bar .015 longer and forcing it in, or using a 1/2 bolt and a rod coupling nut and spreading it .015 with that, or where can I get a spreader?
    I'm using Derlin bushings for the inner from Chuck collins
    Mark Riesch
    New Bern, NC
    Here is the tool copied from the Studebakerparts website. https://www.studebakerparts.com/stud...age=tools.html Just scroll down to front end tool.
    I used a port-power to spread it to the dimension +15 thousands and set my ID gauge to that dimension as I installed the bushings.
    There is no torque spec as the bushings will be stop turning when the bottom on the arm, not the kingpin.
    Bob
      [QUOTE=sweetolbob;531787]Here is the tool copied from the Studebakerparts website. https://www.studebakerparts.com/stud...age=tools.html Just scroll down to front end tool.
      Thanks alot, I ordered a spreader tool. hopefully I'll get my car back on the road soon.
      Mark Riesch
      New Bern, NC
