Front sway bar bushings
  • Front sway bar bushings
    Started the first baby step on my front-end teardown today by removing the sway bar. Lower a-arms were so caked up with grease and dirt inside it took 10 minutes just to find the bolt heads!
    Question: how do you install the inner sway bar bushings? I couldn't get the old ones off going around that sharp bend in the bar; had to cut 'em off. Do you grease up the bar? Soap?
    Clark in San Diego
    '63 F2/Lark Standard
    Old bushings are often hard as a rock. New bushings should be more flexible. A clean sway bar, new bushings and a little silicone spray should do the deed. jv.
      Just DO NOT use silicone spary anywhere NEAR anything you might wanna put paint on one day.[8]
      Miscreant adrift in
      the BerStuda Triangle
        Tire lube or a soap product will make the bushings slippery and will wash off to allow painting.
        !952 Champion Starlight since October,1971. !962 Daytona
        since May, 2007.
