Spark plug removal
  • Spark plug removal
    How do you remove the spark plug on the left side of a Avanti R2? I loosed the shield but cant remove the plugs.
    jerry defilippi
    Very gingerly! (Sorry Jerry, I couldn't resist!)
      You use a 3/8" Drive, 14 mm Spark Plug, Deep Well, inside padded, Socket, short extension and 3/8" Rachet.
      Is there something in the way of ONE? MORE? of your Left Side Plugs?
        The left side spark plugs...especially the ones under the mater cylinder and brake booster...you remove by braille. A spark plug socket with a universal joint makes it much easier. It's the fitting the new plug in blind that's the tough part.
          Thank you to all.
          jerry defilippi
            Originally posted by jerry1 View Post
            Thank you to all.
            I use a small length of hose on the terminal end to use as a flexible handle to install, but taking them out is not that hard.
            JDP Maryland
