Powershift Automatic
  • Transmission / Overdrive: Powershift Automatic
    The Powershift transmission in my 64 Hawk (now with 95,000 miles) hasn't given me any problems since its rebuild in 1987 (at 84,000 miles). I generally drive the Hawk for a few miles each weekend all year long. This past Saturday when I took the car out, the transmission for the first time seemed to be having some problems shifting. I was able to get home and put it in my garage. Then, Sunday, when I started the Hawk, the transmission did nothing regardless of which position I put it in, forward or reverse. My garage is very small and I can't even open the Hawk's hood with the car fully in it or put it on ramps there, so I couldn't really do any checking, but I didn't see any fluid underneath. I hope to pull the car out of the garage this weekend, if more of the ice has melted here and it's not too cold. Are there particular things that I should be looking for? Please reassure me, if possible, that this isn't necessarily a catastrophic failure.
    Mark
    Hopefully it is just very low on AT fluid due to a slow leak. That would be the best, of course it may be something more serious. Good luck! Let us know when you investigate further.
      Just a thought. Since the powershift has cooler lines going to the radiator, check you coolant for trans fluid contamination too.
      60 Lark convertible V-8 auto
      61 Champ 1/2 ton 4 speed
      62 Champ 3/4 ton auto
      63 G.T. Hawk R-2,4 speed
      63 Avanti (2) R-1 auto
      64 Zip Van
      66 Cruiser V-8 auto
        It looks like the immediate problem was low level of transmission fluid. I added a quart plus and now the transmission operates okay. Of course, the reason for the low level still requires investigation...
          What is you middle name Lucky???
          Candbstudebakers
          Castro Valley,
          California
