Accelerator Sticking or Haunting?
  • Accelerator Sticking or Haunting?
    Weirdness I have never experienced.......I believe my Lark is haunted. When accelerating the throttle will either stick, move on it`s own back and forth or accelerate without the peddle moving. This does not appear to be a linkage problem. everything looks square and I also cleaned the linkage and carb. I just rebuilt the carb a couple weeks ago.
    Also... I need to find new linkage on the accelerator where that little ball joint is (next to the kick down terminal). That ball joint keeps popping off.
    Thanks in advance,
    Jason
    Check your throttle pull back springs. If it's a V-8 there should be two of them. If they are missing or weak your throttle could have a mind of it's own.
    Dan Peterson
    Montpelier, VT
    1960 Lark V-8 Convertible
    1962 Lark V-8 Regal Convertible
    Dan Peterson
    Montpelier, VT
      Sounds like a broken motor mount. When the engine rocks over it pulls the linkage. If it gets really bad, it'll flloor it and away you go.
      Studebaker On The Net
      http://stude.com
      Studebaker News Group
      Arnold Md.
      65 Sports Sedan
      64 Daytona HT
      63 R2 4 speed GT Hawk
      63 GT Hawk
      63 Avanti R1/AC
      63 Avanti R2/4 speed
      63 Daytona HT
      63 Lark 2 dr.
      62 Lark 2 door
      62 GT(parts car)
      60 Lark convert
      60 Hawk
      52 Starliner
      51 Commander
      JDP Maryland
        I think you are right, JDP. It feels as if the motor was moving after I hit the accelerator peddle. I off to check it out. The springs are in place and functioning fine Thanks,
        Jason
          I agree with JDP, sure sounds like a motor mount. it's easier to tell on a 4-speed as you will be able to see the shifter stick move when you accelerate. If any mount is broken, it will be at least the driver's side front mount, that's the one that takes all the abuse when you accelerate, and it's also the one that would cause the symptoms you describe. Might as well replace them both while you're in there though. I broke two on my '62 before I just gave up and made my own with the rubber from some old mounts and a through bolt.
          good luck,
            It definately sounds like a broken motor mount
            Studebaker Fever
            60 Lark
            51 Champion
            Phil
            Arnold, Missouri
            Studebaker Fever
            60 Lark
            56 Power Hawk
            Phil Hendrickson
            Arnold, Missouri
              *follow up*
              The problem was the dust boot becoming unlodged and getting tangled in the linkage. Motor mounts good. Back on the road.
              Thanks again!
              Jason
