Hawk Dash removal
  • Hawk Dash removal
    I'm in the process of removing my 58 Hawk dash to recover as well
    as replace a couple of switches. I have two issues I need help
    with, hopefully someone else has done this task before. (it's not addressed in earlier threads). ;;;;
    I have all retaining screws and bolts removed except the bracket that
    holds the dash to the steering column; the manual says only to
    "remove the two bolts".. problem is, after removing the two
    lower nuts I don't see how the two long bolts get removed.
    I tried to drive them upward out of the bracket, but no go. They appear to be pressed (from above) down through the bracket and I can't get the steering column to lower enough to slip the dash
    down off the bolts. any thoughts?
    Secondly, I removed and labled all the wires,,, except one little
    bugger I somehow missed. On the turn signal "module" (behind the "blinkers" on the dash) there are three bulbs and one rather short red wire with connector. I don't know where this red wire connects; the wiring diagram I have doen't show it.. Is this simply a ground?
    any help appreciated. Thanks,
    Joe D.
    The dash has to slip off the studs.Did you remove all the nuts at the windshield base and drop the steering column a bit ? If so, tilt the dash and drop it off the studs.
    JDP/Maryland
    64 Commander
    64 GT R2 clone-63 GT R2
    63 Avanti R1
    63 Daytona convert-63
    63 Lark 2 door
    62 Lark 2 door
    60 Lark HT-60Hawk
    59 3E truck
    52 & 53 Starliner
    51 Commander
    JDP Maryland
      ok, got it off; thanks JDP.. Where the manual says
      "remove the two bolts holding the bracket and steering column
      to the dash" it gives no hint on how to go about that.
      I had to remove the triangular-shaped support bracket
      which is held on by one bolt accessible on the outside of
      the car (cowl) and one under the dash. That allowed me to
      raise the metal framework just a bit while lowering the steering column slightly, allowing me to slip the collar down off
      the two studs; Then.... there
      were two retaining clips that had to be removed as well, before
      I could free up the dash for removal. Anyway,.... all done.
      Now all I have to do is refinish it///// tks again.
        It's a lot easier after you've done a dozen or so. I've taken apart so many Hawks over the years I can pretty much ID every little bolt and clip and that makes life much easier.
        JDP/Maryland
        64 Commander
        63 Avanti R1
        63 Lark 2 door
        62 Lark 2 door
        60 Lark HT-60Hawk
        59 3E truck
        52 & 53 Starliner
        51 Commander
        JDP Maryland
