Need opinions on Waterpump noise
  • Need opinions on Waterpump noise
    At idle, the waterpump on my GT Hawk emits a sort of 'muffled' grinding or growling sound.....kinda like a bearing going bad. But it's intermittant and not constant. And as soon as I increase the rpms above say, 1000 rpm, the sound goes away.
    The waterpump is not leaking coolant and does a fine job of pushing enough coolant around so as not to overheat, even on an 88 degree day. Also, there is no wobble or freeplay in the fan to speak of.
    Should I replace the thing or not? Or is the opinion such that it's something I can probably live with for quite awhile?
    If it were yours, would you chance it going to South Bend?
    Karl
    1962 GT Hawk 4sp
    If it were mine, I'd change it. At the very least, I'd pack a spare water pump with me. A Stude V8 water pump has to be one of the easiest to change in the entire industry. It'd be easy to change on the road, IF you have one with you. Don't count on getting one in a hurry in a strange town. Order one now if you don't have one, and change it at your convenience.
      Are you sure there is no wobble? Did you take the belts off, and try to wiggle the waterpump? Do you have a fan clutch? It could be going out. I would not be inclined to try that trip without replacing the pump, because changing it on the side of the road is not too appealing !!
        While you have the fan belt off, spin the blade and listen for any rumbling of the bearing. If it does, that means you've caught it in time before you're inconvienced or the fan blade goes through the radiator. If it's quiet when you spin it, spin the generator to make sure a bearing isn't giving out on it.
          I have always thought everybody over tightens the belt on studes. I pull the generator back with my hand and tighten it down. Just a little tighter than slipping.
            They are simple to change.
            My inclination would be use one of those noise locators/mechanics stethescope) to make sure it really is the water pump first.
            I probably would not change it, but I would take a spare with me, along with some coolant in a container, and I'll bet you don't have a problem. (If you don't take this preventative step, it will almost certainly fail - don't ask me why - ask someone called Murphy.)
            Don't forget: If you really have to change the water pump, put a piece of cardbord against the rad core to prevent damage.
            Good luck, I'll see you in South Bend.
            Paul R
              Yeah, it does make good sense to have a replacement along with me, 'just in case'. As someone mentioned.....I know this "Murphy" character quite well and he's NO friend of mine!
              Back to topic, when I removed the belt and fired it back up, there was no noise, so at least that confirms that it's not anything else going out. And no, there was no wobble or play or rumble or any sort of 'roughness' when turning/spinning the fan by hand.
              Didn't notice any in the generator either. I tried the "stethoscope" method, first with a short length of garden hose and then with a 24" piece of 3/8" cold roll steel rod with a "bell-reducer" threaded on the listening end, and determined that for sure, the sound is indeed emanating from the vicinity of the water pump.
              As another poster mentioned, it is easy to overtighten the drive belt.....and I made sure it had sufficient tension, and only enough tension to turn the fan and the generator.
              I think I'll take the advice of the one who suggested changing it along the highway (no matter how easy it may be) would be a major inconvenience, and to go ahead and order one now and change it out ahead of time.
              Thanks to all....
              Karl
              1962 GT Hawk 4sp
                quote:there is no wobble or freeplay in the fan to speak of.
                "to speak of" does not sound absolute. With the engine off, if you can detect any inkling of lateral play in the shaft, it's time to replace the pump.
                Brad Johnson
                '33 Rockne 10,
                '51 Commander Starlight,
                '56 Sky Hawk
                  Brad Johnson
                  You're very observant and quite correct in your assessment....I was not being "absolute" when I said, there was no wobble or freeplay in the fan to speak of.
                  There is an infinitessimal amount of "play", which I attribute to standard assembly line "plus or minus something or other", tolerances. Certainly nothing that I would call, "excessive" or at least obvious.
                  I will exercise the route of caution and replace the pump. If after that, I still have the noise.....well, at least I know I will have a spare pump if I ever need it, heh, heh, heh.
                  Thanks for your input.
                  Karl
                  1962 GT Hawk 4sp
                    Karl, if you have the belt off, get your listening device, set it on the water pump or water manifold, and get a helper to spin the fan. If you hear any trace of rumble, change the pump. I'll bet you the bearings are dry, and the balls and races just beginning to develop flat spots. It will go downhill fast from now on.
                      CHANGE IT
                      63 Twin Supercharged Avanti
                      64 Avanti R3w/NOS
                      88LSC Avanti 350 Supercharged w/NOS
                        I just went through a similar thing after installing a new water pump on my Hawk. The horrendous noise turned out to be the pulley hitting th bolts on the pump. I had put in new lock washers on the pump that were thicker. I didn't realize the tolerance was that close. I pulled the fan and pulley and put thinner locks on the pump and the problem was solved. The same thing could happen if the fan pulley was installed askew and it was clipping the bolts.
                        Regards,
                        John
                        John Esmonde
                        Holland Landing, Ontario
                        Canada
                        '62 Hawk
                        '30 Chev Coach
                        sigpicJohn Esmonde
                        Canada
                        \'62 Hawk
                        \'60 Lark Regal Convertible
                        \'30 Chev Coach
                          And while you are at it, change the coolant out if it's of any age older than a couple years....that's part of the preventive maintenance thing.
                          Brian
                          Brian K. Curtis
                            One additional thing to consider is- what happens to your radiator if the water pump gives up suddenly and the fan spins into your radiator? Doesn't happen often, but it DOES happen.
                            Museum R-4 engine
                              I agree with Paul, once had a fan let go on a Avanti and it took out the radiator and shroud. Also have had the fan go through the hood on my 41 Caddy.
                              JDP/Maryland
                              64 Commander
                              64 GT R2 clone-63 GT R2
                              63 Avanti R1
                              63 Daytona convert-63
                              63 Lark 2 door
                              62 Lark 2 door
                              60 Lark HT-60Hawk
                              59 3E truck
                              52 & 53 Starliner
                              51 Commander
                              JDP Maryland
