Twin Traction additive
  • Twin Traction additive
    How much limited slip additive does one need for the Dana 44 rear??
    Dan White
    64 R1 GT
    64 R2 GT
    Dan White
    64 R1 GT
    64 R2 GT
    58 C Cab
    57 Broadmoor (Marvin)
    I tried additives and over the counter gear oil but would get a clutch chatter after some highway driving. Then I took off the cover, again, flushed and then refilled with Redline differential oil. All chattering disappeared, no extra additives needed.
    ErnieR
      None. You can use the additive, but its not necessary. Use Sta-Lube GL-5 rating with limited slip additive. I don't remeber how much you are supposed to use, but the stuff we used to use was in a small tube and we put the whole thing in. Then there is the stuff that Bige mentioned. Was that synthetic? You could go that route but its much more expensive.
      Jake
      -Home of John Studebaker-
      http://s158.photobucket.com/albums/t95/stude4x4/
      http://varozza4x4.com
        Dan,
        I second Ernie's recommendation on the Red Line product. Been usin' it in the car below for many years without any problems. Yes it is a synthetic fluid as opposed to just an additive. Just completely drain your diff removing the cover. You might want to jack up the front of the car higher than the rear to ensure all of the old fluid and sediment will drain out. Should not need "flushing", just drain over night. Install new cover gasket and fill with Redline Diff lube. Also while you're there, check the vent hole on the rear face of the left axle tube aprox. 3 to 4" inboard of the spring perch. Very small hole, IIRC,7/32". Drill bit works great. Hope this helps
        Dan Miller
        Atlanta, GA
          How would the Red Line work on a non-TT rear?
            The red line synthetic will work for all rear ends, TT or no TT.
