232 piston rings
  • 232 piston rings
    The manul lists standard and next size of 20 over.
    I would like to know if there a set available that is actualy ten thousand over the standard set.
    If yes, then who sells them.
    SASCO listed ten over that were actualy standard, that is not what I want.
    Thanks
    Paul
    Just contact Stude International or another of the many Stude Vendors...!
    Another thing to do is figure the correct diameter and width...and contact a ring manufacturer (internet catalog) or two to see if they can help.
      Get the .020" set and a cheap ring filer and file them to size. The 20 overs might be alright as is. Or else you can go to Total seal and they will make you any size gap less ring set you can dream of if you have the money to dream.
        Stude International has standard and twenty over.
        I am guessing the other vendors have the same.
        I need a true ten over.
        If anyone knows who has ten over please let me know.
        Yes Alan, if I can't get ten over I might try a 20.
        thanks
        Paul
          Don't fixate on just the Studebaker. IIRC, several other engines have the same 3.375" bore as the Stude 232" V8.
          Case, Allis-Chalmers, IHC, Mercury outboards, Dodge flathead I6.
          Bottom line, there are several sources for those rings besides Studebaker.
          jack vines
