'48 Champion Starlight back window
  • '48 Champion Starlight back window
    I just purchased a 1948 Champion Starlight Coupe. The rubber around the back windows has rather large cracks in it, letting water enter the car. What can be done to the rubber to seal it from the weather?
    73, Jim
    you need to replace the seals. For a temporary fix you can use Black weather stripping chalking its messy but works in a pinch. Doesn't look real good but it will stop the water.
    Mabel 1949 Champion
    Hawk 1957 Silverhawk
    Gus 1958 Transtar
    The Prez 1955 President State
    Blu 1957 Golden Hawk
    Fresno,Ca
      Thanks, Anne.
      Are the seals available? It looks like quite a job to replace them.
        Seals are available, No. 800800 from Studebaker International, you gotta specify if your car has stainless trim around the windows.
          Before anything is done, get the service manual for your car, available from several vendors.
          Terry
            Thank you. The service manual and parts catalog came with the car. I also have the Motor Auto Repair Manual that cover this car.
            Boy, parts have become very expensive in the last 25 years. It has been that long since I have done any serious repair work.
            Thanks again, all help is appreciated.
              I don't believe any of that body style Starlights had molding around the windows; just the vertical dividers. I also don't know if there is a source for the clips to retain the stainless. I made them when I did my '51 but, does anyone know of a generic clip that will serve the function?
                Yes, and no. That four-piece gasket set does happen to be the most expensive Studebaker window gasket available!
                KURTRUK
                  Bob Palma or some others of the KNOWLEDGEABLE variety will probably chime in here, but as I recall, a (very) few EARLY '47 Commander 5-passenger coupes had the stainless trim, show in some early ads. I think finding one of those would be akin to finding a virgin in Mae West's boudoir.
                  And, my antique brain also seems to recall, it was not actually CALLED a Starlight until 1949.
                  John
                    John
                    The first 500 '47 Champion 5 passenger coupes had stainless reveal moulding around the rear windows.
                    I helped a friend install the reveal moulding front and back on a '50 sedan a while back. I wouldn't want to do it on a Starlight.
                      I had the same feeling when I looked at the entire window. With the old rubber being so hard I am afraid of breaking the glass when trying to remove it. Anne's suggestion of black caulking seems like a good alternative.
                      Merry Christmas to all.
                      73, Jim
                        If you decide to take the rubber out cut the rubber from the inside. Worked good for me.
                          The first 500 '47 Champion 5 passenger coupes had stainless reveal moulding around the rear windows...
                          I don't doubt that you are correct but there was at least ONE Commander
                          John
                            [ATTACH=CONFIG]6175[/ATTACH]
                            John
                            Could've been! Maybe it was the first 500 cars, both models.
                              Many moons ago.. I helped my friend Mike install a rear window in a 51 2dr sedan with reveal. It took all day long. Both of us professed to be christians but nearly lost all our religion before it was over. It never did go in right.
                              Afew weeks later, my son and I replaced the rubber in his 51 Starlight. After dreading it for several weeks, we finally got up enough nerve to tackle it. IT WAS A BREEZE!!! Took us about 30 minutes! But it had no reveal. NT
                              P.S. If you decide to use caulking, try black urethane
                              Neil Thornton
