What is the proper procedure for replacing transmission mounts with the engine/transmission in the car? I.E., where should I place the jack, and what precautions need to be taken? Also, the shop manual talks about adding/removing shims or spacer washers, but doesn't add any other info. Any and all advice would be appreciated.
I'm asking this because after having the engine in my 60 convertible rebuilt, we of course used new motor mounts. Since the transmission wasn't removed, I stupidly didn't bother to replace the transmission mounts when it would have been easy to do so. Result: the front of the engine is a little higher than it was, making the tail shaft a little lower, and the front u-joint now rubs against the center part of the convertible's x-frame on acceleration. Essentially, I need to raise the tail shaft of the transmission slightly so that there's proper clearance.
