How to quiet fuel pump?
  • How to quiet fuel pump?
    Ted H's response to pitbullady made me think about this subject again... how *do* you get rid of a fuel pump knock? I have tried both a rebuilt (by me) R1 fuel pump and a NOS but kitted '55 fuel pump on my R1 engine... both knock. Both did it with the engine only on a stand and a hose in a gas can. The '55 fuel pump was quiet on the previous engine (a '63 standard 289.) Is there anything I can do or am I stuck with an engine that is basically good but sounds like it has a rod knock? I'm *this* close to just spending the $$$ and converting to an electric pump.
    try installing pump with extra gasket and see if it gets better or worse good luck
      How about putting the pump arm in a vise and just tweaking the end of the arm that rides on the cam 'up' a bit. It shouldn't take much.
      Tim K.
      '64 R2 GT Hawk
      Tim K.
      \'64 R2 GT Hawk
        The old dual diaphram pumps were more known for making a knocking noise. Pump noise is usually due to weak/broken springs or wear in the pivot points of levers and links. When we used to rebuild them I was taught after assembly to pack the cavity with heavy chassis grease.
        Dwain G.
        Another thing about wearing a mask......I don't have to shave before I leave the house!
          The copies of old installation instructions for fuel pumps, that come with kits from "The Cellar", say to grease the linkage or immerse it in oil before installing the pump; or a knock may result. But, I've never done anything special.
          Old VW Beetle pumps had a plate, held in place by two small screws, that covered a chamber you were supposed to pack with grease.
          Mike M.
