After several interruptions, I am finally getting back to assembling the 289 that I started last spring. I am assembling the rods to the pistons and I want to be sure the wrist pin bolt won't ever come loose.
I asked this question last spring and I also researched all the other threads I could find and I plan to use the Ted Harbit tap and torque method. Some other suggestions were to also use red loctite. With loctite, I would have maybe 20 minutes to do the tap & torque before it set up. Some of the descriptions of the tap and torque method suggested doing it again after the parts sat overnight. Obviously, this wouldn't work with the red loctite.
What exact method do you use?
Red loctite or not?
The shop manual specifies 20 to 25 ft/lbs torque. If you use loctite, do you back off on the torque a bit since loctite may act as a thread lubricant?
Thanks,
Cliff
Red loctite or not?
Thanks,
Cliff
