Removing '51 Champion Oil Pan
  • Removing '51 Champion Oil Pan
    Hey Guys- Will my oil pan clear the steering if I pull it off from under the car? Thanks, John
    It should come down OK if you simply turn the front wheels to one side. If it looks like clearances are too tight for that, the best course of action is to undo the pinch bolt that holds the steering bell crank to the center pivot. Then remove the center pivot grease fitting, and undo the four cap screws and withdraw the center pivot assembly. That will alllow plenty of "flop" in the bellcrank to permit the pan to come off. It will also give you an opportunity to clean, inspect, and re-grease the center pivot assembly, which tends to be neglected.
      I removed my pinch bolt and let the steering hang down like Gord says. I was retrieving a valve spring retainer I dropped while replacing the valves. Anyway, the only trouble spot is working the pan off of the oil pump pickup tube, but that just requires a little wiggling. If your lucky you won't have to do this lying on your back in a gravel driveway like I had to at the time.
        You highly successful Studebaker entrepreneurs should have concrete paved driveways and paid man servants to attend to these menial tasks.
          I applaud your honesty!
          (And will admit to having been in a similar situation in the past).
          Eleventeen hours of unsuccessful fishing could have been replaced
          with a three hour (I work slow) pan R&R.
          I will never get those lost hours back..
          Thanks for sharing your agony and joy.....
          <snip>
          <snip>
