when it rains, it???oh yeh pours!!
  • when it rains, it???oh yeh pours!!
    well this is a runoff of the not enough vacuum tread, i adjusted my valve lash down to 12 as ted suggested and it fired up fine, idled kinda rough and as soon as i put it in gear and tried to go it just died. it started beck up a few times and gave me the same business, i made a couple small timing adjustments and same thing kept happening. now it will start for about 1-2 seconds and then dies instantly. a very crisp shutdown. i checked for spark and there is plenty of it, plenty fuel, and i even backed the lash back off to 18 and no change, fires up and dies. what could be going on here, i'm going nuts guys, help me!
    notsoslow64
    1964 lark daytona
    bd_marks@yahoo.com
    I was not part of that original thread .... but set lash to 12?? That
    will keep all the valves from closing and most likely burn them. Not
    sure about adjusting them so tight. Maybe I am missing something, but
    I would say your engine temp exceeded the valve sealing and now it can
    not create compression. Wait til it cools down (couple hours) and if
    it starts right back up then your valve are WAY too tight. Spec is a
    max of .023 hot/.025 cold, if memory serves.
    Tom
      in the old tread ted mentioned that since i have an R2+ cam which is a reground it can be set tighter. the thing that kills me is that it ran at its tightest warmed up pretty good, and now won't run at all after sitting for about 24 hours.
      notsoslow64
      1964 lark daytona
      bd_marks@yahoo.com
        Wow! Ok. Well, Ted would be the one that knows about the R2+, I had
        an R3 regrind in the Hawk and always set to .026 cold.
        The fact that it ran, and now doesnt is puzzling. You might try a
        compression test to get a baseline. They should be consisent, and
        none should be less then 100 psi. 120 psi is usually a tired engine,
        and a higher compression new engine should be over 165 psi. I used
        to get 180+ with the Hawk, that was with flat top pistons. (~9.25:1)
        Tom
          Whenever an engine seems to start and run in the "Start" position on the ign. switch, and dies as soon as you switch it to "RUN" or "ON" I suspect the RESISTER or resistance wire. Sounds like it "might" be possible in this case. If you bi-passed the resister when you checked for spark, you missed it!
          Studebakers Northwest
          Ferndale, WA
            I'm with Rich on this. The "I" terminal on the starter solenoid bypasses the ignition wire/resistor so long as you're cranking. The moment you let the key spring back to the run position, the engine's gonna get it's coil power from the resistor and associated wiring. If the reisitor's bad or the wiring going to it is bad - it's gonna be just as if you turned the key off.[}]
            Miscreant adrift in
            the BerStuda Triangle
              In addition to what Rich and Biggs said, you may want to check the ignition switch itself. Soon after I got my '62 GT Hawk it died as I was making a turn into a shopping center. It would catch and die so I pushed it and dumped the clutch and it started.
              It turns out that when I released the key when starting it would retreat to a "dead" zone and die out. However, when I moved it back manually it would continue to run. Almost 4 years later I have still not fixed it but know the solution.
                well guys as suspected the resistor was shot. its so weird that it happened right after a valve adjustment. i did some research on my ignition setup and the coil i am running with my pertronix doesn't require a resistor so i just bypassed it and now it runs. i adjusted it back down to .012 after adj. it to.018 to rule it out, and there's one other thing thats like a slap in the face, this whole time i thought my flat spot was coming from my carb or bad valve adjustment, it ending up being bad gas, i switched from 87 to 91 and the flat spot went away instantly, i should have known better then to put 87 in with flat tops but oh well problem solved right?
                notsoslow64
                1964 lark daytona
                bd_marks@yahoo.com
                  Yah .. welcome to old tech performance. My Avanti pings like a son of
                  a banana if I dont put 91 in, and its lucky to be making 100 hp.[:I]
                  Tom
                    You're doin' good, benny! I wanna hear from you, how it RUNS! once you get the bugs evicted![]
                    Miscreant adrift in
