I have my 289 torn down and was taking some measurements this weekend. Before tearing the engine down, I did a compression test and all cylinders were between 150 and 160 psi. The tear down was due to a knock.
The knock turned out to be from a couple rod journals that are in very bad shape. They would have to be welded up and turned back down to save this crank. The cost of that is only $10 cheaper than buying a NOS crank so I plan to buy a new crank.
The pistons and cylinder walls look great, no scratches or pitting and no ridge around the top of the cylinder. The cylinder bores all range from 3.568 to 3.570 so they are about 0.007" over which tells me wear and not a previous bore. Not sure where the ridge at the top went, maybe it was cut away during a previous overhaul.
I measured the pistons around the skirt at about the pin level. They were all either 3.557 or 3.558 diameter. Is this the correct place to measure piston diameter?
The math tells be that with the wear to the pistons and the wear to the cylinder walls, I have about 0.005 clearance between the piston and cylinder wall all the way around. Or about 0.010 total clearance if the piston is up tight against one side of the cylinder wall.
Does this amount or cylinder / piston wear call for a rebuild or does it just need a cylinder hone and a new set of rings?
