Hill Holder.........
  • Hill Holder.........
    How many on this forum have Studes with a hill holder...........and if so it it operable?
    My '55 Champion has one and it works great.
      Hill Holder Adjustment
      55 Champion,
      Please contact me at 56cvytrk@bellsouth.net concerning hill holder adjustment methods. Thanks
        My '54 sedan does, the only one of my Studes to have one, and it is great.
        Adjustment is detailed in the shop manual by the way.
        Paul
        Winston-Salem, NC
          Quite a few around the shop have it, and if it's drivable. it works. The 56 Commander I drove to Pa. worked great and came in handy a couple of times. The '41 Commander that I drove to Az. also worked. Nice not to not roll backwards at some of those hilly red lights.
            Greetings From Northern Minnesota. I have a 1948 Studebaker Land Cruiser with Hill Holder. The Hill Holder works great, although I have no use for it in a state where the highest elevation is just over 2000 feet above sea level. grantwriter1@msn.com
              The shop manual is a joke as far as a clear understandable how to..........and how does one clean out the inside........mine no longer works?
                Well how bad is 'slipping' the clutch if the no-rol is n/g?
                  Slipping the clutch is usually not a good idea, but as long as you don't smell it burning it might be ok. Rebuild kits for them are relativly inexpensive, but are just the seals. Our hill holder has only worked once or twice. I think it's just dirty inside, but I haven't taken the time to pull the thing off and clean it out. We got the rebuild kit, but have since misplaced it! If you're qualified to do your own brake job, you can probably rebuild the hill holder.
                    I have a '55 President with a newly installed hill holder. The original did not seem to work and I picked up a NOS in South Bend or York. It works fine. SI have hill holder kits. I did not bother buying the kit as I found the unit complete.
                    55 President Deluxe
                    64 Commander
                    66 Cruiser
                    37 Oldsmobile F37 4 Door
                      My 56 Hawk has one, and it works just fine. Is there a way to disable it in reverse though? Living in NW Indiana (similar to what the person from MN said), I have very little use for it. The only time mine gets used is when I'm backing out of my driveway.
                        I ordered my '64 Daytona Wagonaire with a Hill Holder. It still works. However, the car has disk brakes and the Hill Holder only works on the rear wheels so it isn't as good as the earlier ones that hold all four.
                        I have owned several other Studebakers with Hill Holders and they all worked fine.
                          Avantis with no-rol have all four wheels locked.....so something must be broken on your wagon.
                            Our '53 has one but have not tried it as the car has been in the restoration process for over seven years. We hope to have it finally finished soon after the new year, knock on wood. Then I will look for a hill (not many close) and try it out.
                            Tim-'53 Starlight Commander Custom in Yuma, AZ
                            jimsrodshop.com/project/53-resurrection
                              Rebuilt and installed one on my 64 Hawk, because the driveway is on a 12 degree hill. Works great! Dan
