My fan has been hitting the shroud the last few times I've had the car out and I will be changing the motor mounts soon. The fan has small nicks on the edge of the blades. Not deep but nicks just the same. I think I know the answer to this question but I'll ask anyway. Should I change the fan blades also?
Should I get a new fan?
These are cheap stamped steel. You can ignore them. Years ago I was working on a 68 Dodge Dart that some drunk had run into while parked. The radiator was jammed back over the fan. I pulled the fan off and beat the blades back somewhat into shape with a hammer. Ran fine but looked like hell. Needed a new radiator though.
Nathan
A friend of mine had a nice '67 Mustang...
As he came by my place, there was this 'whack' sound and then he stopped.
Said his engine was vibrating bad.
Went to open his hood and noticed a nice 'slot' in the top of the hood.
Went ahead and opened it and looked inside to see a three bladed fan.
You are right.... Just cheap stamped sheet metal, some rivets, and some bolts.
Originally posted by nvonada View PostThese are cheap stamped steel. You can ignore them. Years ago I was working on a 68 Dodge Dart that some drunk had run into while parked. The radiator was jammed back over the fan. I pulled the fan off and beat the blades back somewhat into shape with a hammer. Ran fine but looked like hell. Needed a new radiator though.
NathanHTIH (Hope The Info Helps)
It is a good practicet to check your fan blades periodically for stress cracks.
Do not repair , but replace a suspect fan. A fellow service manager had a fatality in his shop when a repaired fan blade that was welded broke and hit a mechanic.
Husband of Lark VIII girl
Was working on my 64 daytona yesterday. Went to sandblast the fan before I repainted it. Noticed two cracks opposite eash other near the rivits. Time for a new fan before it goes through the hood or through my head when I am timing the car!!!
T-Cab
