Need year model I.D. of Unmarked Champion 6 Engine
  • Need year model I.D. of Unmarked Champion 6 Engine
    Please see easily readable post number two.
    Thank you, Rich.
    OK, now I need a little Champion 6 help here!
    As most of you know I am strictly a V-8 guy, I have one overhead valve Six, but mostly always had and have the V-8's.
    So It comes as no surprise that when a friend asked me how to tell if the replacement engine in his '51 R series Truck is of the '39-'58 Variety or the '59-'60 type using different pistons, I don't know.
    It is a replacement engine and is a 169 c.i. flathead small six, but it has no Serial number because it's a replacement and may be the more common replacement '59-'60 Lark Six, but I need the casting numbers of each to tell them apart.
    I checked the 6 Cyl. Serial number listing hoping to find some casting number info, but none is listed so I am asking for the Forum members help with it, please.
    Thank you, Rich.
      In a forum search I found this post: http://forum.studebakerdriversclub.c...asting+numbers
      where I did find this good info posted By Dwain G. Quote: "Those are engine block casting numbers, not engine serial numbers. 518448 was used from about 1947 to '49 or '50. 524807 was used from about 1951 to '54. Use the sump and pan from the earlier 518448 block."
      This should help if it is an older block, this is part of the puzzle but not all of the info needed.
        1955-58 185 blocks have casting number 533870, and 1959-60 170 blocks are 1548965.
        There's also date codes to be found near the distributor that might narrow the engine down to a particular model year.
        Another thing about wearing a mask......I don't have to shave before I leave the house!
          Thank you very much Dwain!
