WooHoo! Bell housing dial in is DONE! (almost)
  • WooHoo! Bell housing dial in is DONE! (almost)
    Dialing in the bellhousing must be one of the most tedious jobs I can think of, especially trying to do it by yourself...Jane's travel make-up mirror was a big help though. I did wipe the evidence off of it afterwords, so I don't think I'll get caught.
    Even though I was going to be satisfied with .003" run-out, that last tap brought it to 0.000" vertical and.002" horizontal. I torqued the bolts down, verified that it did not change, and now just need to get the reamer and pins! I really will finally get this engine installed!
    Ron Dame
    '63 Champ
    Way to go dude!!!!
      what a miserable job. Congrats on the tight tolerances.
        do you need to dial in a automatic trans converter and bell housing if it all was removed?? I did not pull the flywheel but did pull out the converter and bellhousing. Thanks RC
          The cars left the factory with a matched engine/bellhousing. You only need to do the dialin if you swap out the factory setup for a new trans or engine.
          64 GT Hawk (K7)
          1970 Avanti (R3)
            You are my hero, Ron. Coming from the Big 3 world I've never done one, and have thus far been able to avoid it; but it's just a matter of time. Just can't seem to get my mind around the process. I'm sure when I come to a point where I HAVE to do it I'll figure it out- like I still don't get what a "reamer and pins" are for Nice work conquering it!
            Proud NON-CASO
            Romans 15:13
            Deuteronomy 31:6
            Proverbs 28:1
            Illegitimi non carborundum
              The reamer is to enlarge the alignment holes and true thiem up with each other so a larger pin can be used to maintain alignment if the bell is pulled again.
                Like you, I'd not quite got my head around it, yet now that honest and for sure I'm going to install the new engine, I couldn't put it off any longer. But then once I began, it became pretty plain. I think you just have to do it to understand it. My biggest problem was trying to decide which way I needed to tap the bellhousing to align it, and going the wrong way :-(
                Ron Dame
                '63 Champ
                  Yeah, Ron, I learn things like that MUCH better being shown even one time. I'm sure I'll figure it out once I can no longer avoid it <G> Somewhere I got the idea that once it's aligned completely new holes were drilled through the bell into the block and new pins installed.
                  I'll look into it again at a later date........................
                  Proud NON-CASO
                  Romans 15:13
                  Deuteronomy 31:6
                  Proverbs 28:1
                    I've done several dial ins on V8s but the Champion 6 had me stumped when I was looking at it.
                    There doesn't seem to be any provision for picky alignment.
                    Do they not need it because of their small diameter clutch?
                    Lark Parker --Just an innocent possum strolling down life's highway.
                      I don't know about car Champ engines, but on the 8E trucks, you have a V8 bellhousing, flywheel and clutch
                      Ron Dame
                      '63 Champ
                        Look on Bob Johnstone's site. There's a great pictorial that helped me a lot.
                        Ron Dame
                        '63 Champ
                          FYI... They (the big 3) suggest this, too (if you read deep enough in their manuals..).
                          Just is, very few take the time to do it.
                          And Lakewood sells adjustable pins for their replacement bellhousings to make the job easier.
                          I check all the Stude's I do...Only about a third of them need any adjustment.
                            Last night I had one of those 2:00 ayem 'UH-OH"s! I started with the 9:00 position at 0.000" 6:00 was 0.002" 3:00 was 0.000", and 12:00 was 0.001". It sounds like the runout is fine except why is it not 0.000:, 0.000: 0.000" and 0.001"? Was my set-up wrong? Is the hole oval? does it really matter? HELP! I need to sleep tonight!
                            Ron Dame
                            '63 Champ
                              A small glass of good wine just before bed should do the trick.
