I have a '61 Hawk with Strato-Vue side mirrors. The driver's side mirror frame has increasingly become loose on the ball and socket pivot point, and as such won't hold a position. It "droops" from the affects of road vibrations and wind. Any ideas about how to tighten the ball & socket interface?
How Do I Tighten Strato-Vue Mirror?
Mine did that and I just removed the mirror head from the body by loosening the set screw and tightening the ball part back up by screwing it in with a pair of visegrips. On mine it is threaded into the mirror head. I might add mine is a reproduction.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
Jim Bradley
Lake Monticello, VA
'78 Avanti II
Lake Monticello, VA
'78 Avanti II
Thanks Jim, I successfully found the "thread" through your link. I had a similar idea for a fix, which was to use a nail set or other tool to "bend over" the female portion of the ball and socket. I like the idea better of roughing up the ball as suggested in the previous forum. Much obliged!
Originally posted by 41 Frank View PostMine did that and I just removed the mirror head from the body by loosening the set screw and tightening the ball part back up by screwing it in with a pair of visegrips. On mine it is threaded into the mirror head. I might add mine is a reproduction.
Frank, I don't understand what you did.
From what I can tell the mirror head includes the swivel ballstud. This ball stud can be remove from the mirror casting. So how did you tightenup the ball stud swivel?
Thanks
Tom
Well like I indicated I backed the set screw out enough to remove the head and ball stud as a unit and since it seemed at the time the ball stud was screwed into the mirror head I just screwed it back in tight and used a vise grip to secure it tight. Has been secure for several years now. Maybe yours has a different design or problem. Mine was a repro Stratovue though.
Originally posted by tomhoo View PostSorry about resurrecting a "stale" thread, but it is a continual problem.
Thanks
TomFrank van Doorn
Omaha, Ne.
Originally posted by 41 Frank View Post...since it seemed at the time the ball stud was screwed into the mirror head I just screwed it back in tight...
If you screwed the ball stud back into the mirror head, wouldn't the same thing be to simply screw the mirror head "onto" the ball stud while it was still attached to the mirror frame/casting?
Yes you could do that I suppose and at first I tried that but it kept coming loose. The ball stud tends to turn as the set screw won't hold it tight enough, therefore it was as easy since it only took seconds to remove the mirror head with stud to do it the way I did it and get it really tight so the problem would not reoccur.
Originally posted by tomhoo View PostThat doesn't explain what the mechanism looks like inside the mirror head, but who knows, maybe that is all that is required.
If you screwed the ball stud back into the mirror head, wouldn't the same thing be to simply screw the mirror head "onto" the ball stud while it was still attached to the mirror frame/casting?Frank van Doorn
Omaha, Ne.
