Timing gear/chain?
  • Timing gear/chain?
    I gather the V8 has timing gears not chains. What do you order to have parts on hand? Any 'jober' for Studebakers have a kit?
    No 'full set kit', per se...
    But all the parts can be obtained from the vendors listed right here on this website...
    http://www.studebakervendors.com/
    For example:
    Fairborn Studebaker has the aluminum cam gear and reground cams available: http://www.fairbornstudebaker.com/
    Dave Thiebault makes a great billet aluminum Mallory distributor, and can rebuild your AFB and WCFB (and WW) carbs for you...
    Lionel Stone has some high performance parts reproduced: http://www.studebakervendors.com/lstone.htm
    Studebaker International, Myers Studebaker, Stephen Allen's Auto.. All have rings, bearings, gaskets, etc.
    Your local Jobber might even be able to get all the gaskets still made by Fel-Pro (except the rear main seal kit)..
    You can spend a lot of time shopping around, or you can use the resources listed right here on this site.
    DEEPNHOCK at Cox.net
    Ocala, FL.[u](For ONE more week!)</u>
    '61 Hawk (project)
      The timing gear is not a typical part needing replacement even during a engine overhaul.
      Studebaker On The Net
      http://stude.com
      Studebaker News Group
      Arnold Md.
      65 Sports Sedan
      64 Daytona HT
      63 R2 4 speed GT Hawk
      63 GT Hawk
      63 Avanti R1/AC
      63 Avanti R2/4 speed
      63 Daytona HT
      63 Lark 2 dr.
      62 Lark 2 door
      62 GT(parts car)
      60 Lark convert
      60 Hawk
      52 Starliner
      51 Commander
      JDP Maryland
        AND..... since the crankshaft gear is steel and the other one is a fibre-plastic composition (unless it's the high-performance aluminun edition), it's almost NEVER that you need to replace the steel (crankshaft) gear.
          So, I imagine the fibre gear should be changed out during an engine rebuild, right? Is there any reason to move to the billet gear for a car that's going to be just a driver?
          Clark in San Diego
          '63 Lark Standard
            Not unless you plan on keeping this car until your GRANDKIDS get it!
            It was only used on Avanti and the special order HD Truck engines.
            Clark in San Diego
            Studebakers Northwest
            Ferndale, WA
              The Rock Auto Parts data base shows the rear main seal as Fel-Pro part # BS100531. There used to be a pictue of it; with the two little cork pieces. The Stude venders listed probably have them; or you can order from "Rock".
              Mike M.
