My '78 Avanti has an R-12 system with a GM style compressor. The rest of the system is essentially the same as the Studebaker Avanti set-up. There is no binary switch. The control circuit consists only of the fan On/Off switch w/ rheostat, and the thermostatic switch, which is energized whenever the fan is on. It blows really cold air, and keeps the car comfortable on the hottest days.
My problem is that the system seems to cycle excessively. The compressor generally runs for 20-25 seconds, then shuts off. But, after only about 15-20 seconds, it comes back on. I can't believe that this frequent cycling is good for the clutch and/or drive belt. The sight glass is very clear of bubbles. Unfortunately, I don't have a set of R-12 gauges.
I recently replaced the thermostatic switch, but the cycling remained about the same. Is it possible that the system is actually overcharged? The end of the thermostat tube was tucked into the fins of the evaporator. Is this correct? Any other thoughts/suggestions would be appreciated.
