Time to rebuild front suspension on my 59 Lark. Wondering if its worth it to re build and do they drive nice when done, or cut out and put in like a mustang IIor custom mod? Is there a Studebaker front suspension kit out there or do I just have to buy piece by piece? Thanks
front suspension for a 59 Lark?
Originally posted by The Leak View PostTime to rebuild front suspension on my 59 Lark. Wondering if its worth it to re build and do they drive nice when done, or cut out and put in like a mustang IIor custom mod? Is there a Studebaker front suspension kit out there or do I just have to buy piece by piece? Thanks
They don't drive like modern cars, but they do pretty well once everything is tight and most importantly well greased.
nate--
The Studebaker kingpin system may be archaic, but it is sturdy. You will never see a Studebaker alongside the road with a wheel cocked out 45 degrees due to a broken ball joint.
Phantom does sell a complete supposedly bolt-in kit with rack and pinion, etc. Ask Pat Drnec how easy his was to install (not).Last edited by 53k; 06-10-2010, 01:39 PM.Paul Johnson, Wild and Wonderful West Virginia.
I can't remember what years used needle bearings in the kingpin and center pivot, but be aware when disassembling that they may be there - they have loose needles like a U-joint.
nate--
FWIW, the Studebaker front suspension with all new wear parts will ride and drive better than most of the hot rod front clip jobs I've seen over the years. This is from a guy who has built many hot rods. I kept the Stude front suspension in my personal hot rod Hawk. It will also cost less to rebuild and will be worth more on resale than a modified car.
thnx, jack vinesPackardV8
Go for the rebuild of the Stude front end! It's not cheap, but cheaper that an aftermarket kit or stub,and certainly easier. A machine shop can help press in new kingpin bushings, and ream them for a perfect fit, too. If you follow the shop manual it is not too bad, and all the parts are available from Stude Vendors.
