I'd suggest reading up on rear end maintenance. If your not sure when the last time the axle bearings were serviced you'll have to at least start there. Also take a look @ the backlash of the ring gear to pinion. Remove the differential cover and inspect the unit as best you can you might also get some gear pattern compound and check the pattern of the gears if everything else checks good.
Does it make the noise under acceleration, or deceleration, or all the time?
Good Luck
57 SH (project)
60 Lark VIII 2dr sd (driver)
Good Luck
57 SH (project)
