Electrical Rust Removal
  • #16
    This method is also environmentally friendly. The crud that results can be used to green up your lawn.
    Terry
    • #17
      I wonder if using a battery in conjunction to the battery charger would protect the charger. Many of the chargers will burn up if turned on without a load. I have a charger with instructions to turn off the charger before disconnecting from the battery.
      • #18
        Originally posted by bams50 View Post
        This has alway seemed neat, but really just a gimmick to me. Why is it better/easier/quicker than just using any of the multitude of other methods?
        Certainly not a gimmick to me. Cost less then $5.00, gets rid of rust in any area that the liquid can get to, and requires very little labor. I have a Avanti trunk latch cooking as we speak.
        JDP Maryland
        • #19
          John
          Because you are actively involved in this technology, What is the usual amperage of the charger you use on parts like the trunk latch? Thx
          Bob
          • #20
            John
            Bob
            It's only drawing 3-4 amp right now so it's on a small charger. Set it as high as you like, the size of the part determines the current draw. i.e. a cylinder head may draw 20 amps or more with a big anode. You can even derust the inside of a gas tank by just filling it with the solution and suspending the anode away from tank sides.
            JDP Maryland
