Vacuum wipers
  • Vacuum wipers
    I am working on a 1955 Champion with vacuum wipers. Can I change over
    to a later 12 volt wiper motor fairly easily?
    53commander HDTP
    53 Champion HDTP
    61 Cursed Purple Hawk
    64 Champ long bed V8
    53 Hudson Super Wasp Coupe
    YOU DRIVE YOUR STUDEBAKER IN THE RAIN!!?
    Really though, I got caught in an unexpected downpour yesterday and they worked just fine, once I found a place to pull over and stop.
    Dick
    Mountain Home, AR
    http://livingintheozarks.com/studebaker.htm
    Dick
    Mountain Home, AR
    http://www.livingintheozarks.com/studebaker2.htm
      I would assume so, I would think that you would need an electric motor from a 53-55 sedan and the matching switch (or 56-60 if you have converted to 12V; the early switch works fine on 12V)
        The vacuum wipers are my '50 Starlight really suck so I tried a few things. Went to a double sided fuel pump. It worked a bit better. Used some teflon spray on the inside case of the wiper motor where the flapper rides. Worked a bit better. Best bet was to use rain-x. It worked great. Bugs have as hard a time sticking to the windshield as the rain does. Options: Move to the dry flat-lands! [8D]
        StudeBakerHarv
        StudeBakerHarv
        * 1950 Champion Starlight Coupe (Cathcart Stg 4 Engine)
        * 1971 Avanti II (RQB-1659).
