259 Oil Pan
  • 259 Oil Pan
    Does anyone know where I can get an oil pan for a '63 Lark with a 259 engine?
    Are you looking for new or used? New (NOS) is probably next to non-existant. Useable should be fairly easy.
    Miscreant adrift in
    the BerStuda Triangle
      You need to order a 1539382 '56-'57 V-8 will work, or a '58-'64 (all V-8's) 1547193 with smaller 3/8" drain plug. Check the vendors at studebakervendors.com
      I didn't find one at SASCO.
      Studebakers Northwest
      Ferndale, WA
        Used is fine, the one on my Lark is quite rusty probably from sitting for 19 years in previous owner's garage.
          ANY I might have are gonna be "rusty" to a degree. Rusty can be dealt with thru chemically cleaning or by bead-blasting (Althought I don't LIKE bead-blasting engine parts too much because I worry about the glass beads hiding and coming out to "play" when the engine heats up!)
          As long as your's isn't rusted THROUGH - it should be perfectly serviceable.
          Miscreant adrift in
            Biggs internal engine stuff they make walnut hull media to blast with
            3E38
            4E2
            4E28
            5E13
            7E7
            8E7
            8E12
            8E28
            4E2
            59 Lark
            etc
              Can I pour some in my crankcase, Charlie? I've got a box of it here.
              Miscreant adrift in
