T-96 1A transmission
  • T-96 1A transmission
    I'm looking to upgrade my 51 champion from 3 speed to 3 speed w/OD, and I have an opportunity to get a T-96 1A transmission... Any idea what the 1A refers to? Is this the correct transmission for my 170 ci champion?
    I've seen a few transmissions available, but shipping/transporting seems to be a stumbling block, so if anyone knows of a "correct" transmission for me in the area of Las Vegas, let me know! Thanks.
    Las Vegas, NV
    '51 Champion Business Coupe
    T-96 is the model number of the transmission as assigned by Borg-Warner.
    "1" is the group number/casting number for the main case. The suffix letter indicates what application it's used for.
    I went out to the barn and checked: T-96 1A is an overdrive main case; T-96 1 is a straight 3 speed. In addition, the rear (overdrive) housing should be marked R10A-1E, or R10B-1E.
    Ask your seller if the rear housing is so marked. Also, you should be getting the solenoid, a large cylinder which mounts to the rear of the shift levers, and governor, a smaller cylinder which mounts low on the opposite side of the O/D housing. Get a complete transmission at least. You can make up substitutes for the control cable and relay if need be, the governor and solenoid not so.
