63 289 engine
  • 63 289 engine
    Can anyone help? Is the 289 Stude block and heads an early representation of a ford 289 or chevy 327, or is of no comparison. If you were looking to buy aftermarket, compressor/alternator brackets, any idea of all that are listed, which ones to buy? Thanks for the insight.[]
    Studebaker engines are not the same as Chev or Ford. Parts don't interchange. No comparison.
    Klif
    55 Speedster
    42 Champ Coupe
    55 Speedster/Street Machine
    63 Avanti R2
    64 Convertible R1
      Read this 1000X.....
      Other than being a V-8, a Stude 289 is NOT a ford (or chevy), in any way, shape or form.
      If you buy an aftermarket compressor, the only viable option is a Sanden rotary and they have mount tabs on 8 corners, so you shouldn't have any trouble mounting it.
      If you have an old generator bracket and a drill, you can mount a Delco alternator without a problem. Probably other ones too, but I only use the cheap stuff.
      Bob Johnstone
      64 GT Hawk (K7)
      1970 Avanti (R3)
        Vintage Air sells two styles of brackets, the crank pulley, or the entire AC kit. You can also add the Studebaker parts found on ebay quite often. Vintage Air also sells the Sanden to Studebaker adapter.
        64 Commander 2 dr.
        64 GT Hawk R2 clone
        64 Daytona HT
        63 R2 4 speed GT Hawk
        63 Avanti R1
        63 Daytona convert
        63 Lark 2 door
        63 Lark 2 door #2
        62 Lark 2 door
        60 Lark HT
        60 Hawk
        59 3E truck
        52 Starliner
        51 Commander
        JDP Maryland
          Our own forum member (railway) has mounts and whatnot to put AC on a Stude as well.
          Miscreant adrift in
          the BerStuda Triangle
            And, he is good to deal with (helpful, knowledgable). I just bought a complete setup from him. I might have gotten it cheaper directly from Vintage Air (and maybe not), but I wanted to be sure I had everything I needed. The evaporator looks a bit like the '64 factory unit, but is more compact.
            Museum R-4 engine
              Let's not forget that railway (Ebon) is a Stude guy, thru and thru. He and his dad both!
              Miscreant adrift in
